Moderator: nsaneM3
Alfaholic wrote:Ok some feedback:
This version of the file was tuned to see if we can increase midrange and just generally how the car performs with the small changes...
Throughout the process Leon told me he only made small changes.
The midrange has seen an increase of 20wHP as Leon litterally only played between 3000-5000 rpm not wanting to change the over boost just yet.
We then looked for more peak power and we changed some boost at overboost, peak power didnt increase much but torque did, a 30wNM gain was achieved at peak and only 3wHP at peak with the final version of this map.
More work will go into the map as only timing and boost was adjusted, off the dyno is where the REAL changes are felt...and heard!
The car spools soooooo quick now joh, midrange is great as thats what i was looking for, the punch in N is great, feels just like D...D is just a bit "more" as per normal.
The Graph looks great too as the boost is smooth until over boost where it now stays the same at 1.4bar peak boost...so that is where the power will come from as it stays the same at peak boost.
Leon says hell liaze with the Italian tuners to find the solution.
He also said he actually messed up, he wanted to do another stock run before we flashed the car, so the next development session will see the car flashed back to stock, dyno runs to get a read of before and after on the same day and the same temps etc...we did the power runs in the afternoon abot 3pmish...Ronnie was there too.
All in all some more work is needed, we reckon 20 safe BHP more to compliment the hardware mods.
I, quite happy with the torque as it is now, but it can be a bit more in higher rpm...development work to continue!
nsaneM3 wrote:next mod for the alfa has to be water/meth, it will get intake temps down also allow us to tune a bit more......dont want to go to aggressive with the tune , want to design a nice pump fuel map and a race map for meth and ob........
Alfaholic wrote:I like how smooth the map is, its extremely smooth, the car pulls and it does not stop pulling, when i race or drive spiritedly, I change at 5500 to 6000rpm, I NEVER go over anymore since I saw where all the power is made...
Return to FR&R Tuning South Africa
