1.8t ---> 2.0t with pistons
For all performance related upgrades this is the forum to discuss and get information from....
Post a reply
Postby wpGTI » Fri Sep 21, 2012 12:06 pm
Hi,
In the last speed and sound mag(i think), there was an advert for ?Wossner? pistons that would increase capacity on the 1.8t to 2.0t.
Question is: why have i not seen many of these 2.0t 20v monsters running around, or any build threads? is it impractical, or just a waste of cash?
I would have thought the change in capacity alone would already add a bit more power across the rev range?
2007 Polo GTI
wpGTI
Newbie
Top
Re: 1.8t ---> 2.0t with pistons
Postby Sean_G6 » Fri Sep 21, 2012 12:23 pm
I dont think it would be a straight fit , you would surely have to "make them fit" (Moer them in)
Sean_G6
GTI Driver
Top
Postby MJP » Fri Sep 21, 2012 12:26 pm
You will have to rebore for the pistons to work.
The only race you have to win is the race against yourself - there will always be someone faster and stronger but there will never be another you, so look within and push your own personal boundaries.
MJP
Site Admin
Top
Postby Sean_G6 » Fri Sep 21, 2012 12:38 pm
Correct , probably re-sleeve
Sean_G6
GTI Driver
Top
Postby Wazza » Fri Sep 21, 2012 12:46 pm
Stroking a 1.8T is not as easy as dropping new pistons in
http://www.intengineering.com/stroker-k ... mahle.html
alot has to change to make it work
Wazza
GTI Driver
Top
Postby keagz08 » Fri Sep 21, 2012 1:11 pm
Not worth the risk IMO
The 1.8T is a masterpiece for strength and reliability... Probably the strongest built mass produced turbocharged VAG motor to date
There's so much more to gain from doing mods around the motor rather than internally ;)
Keagz
Sublime Shine - Cape Town
Polo GTi
CPi Tuned
keagz08
GTI Driver
Top
Postby wpGTI » Fri Sep 21, 2012 1:36 pm
ahhh, so thats why i havent seen them.lol. thanks for the input tho...no way i was gonna do it tho. . .
2007 Polo GTI
wpGTI
Newbie
Top
Postby yosh » Fri Sep 21, 2012 6:29 pm
I have 2.0 build and to use those pistons you will need fsi crank (due to stroke) and oil pump gear, amongst other things lol
UNITRONIC Stage3 Ibiza CUPRA +480whp
Why be boring when you can drive a Unitronic SEAT
yosh
GTI Driver
Top
Postby teamx » Tue Sep 25, 2012 1:06 pm
It's been successfully done many many times.
Yosh can attest to the benefits...
Fast and cheap won't be reliable, reliable and cheap won't be fast, fast and reliable won't be cheap.
2007 SEAT Ibiza Cupra 1.8T
Unitronic Stage 2
Ex:
2006 Polo 2.0
2007 GTi (DSG)
1999 Honda Ballade VTEC
1996 Mk1 Golf Chico 1.3
teamx
GTI Driver
Top
Post a reply
Return to Performance upgrades
Users browsing this forum: San and 1 guest
