Howzit man,
How much is your software for a corsa opc??
Moderator: InBoost
TiaanPGTI wrote:Howzit man,
TMN wrote:Go with Nasen you wont go wrong best tuner in SA. the corsa opc he did in CT beat 230kw ST's...murder she wrote all the way.
1SickG6 wrote:TMN wrote:Go with Nasen you wont go wrong best tuner in SA. the corsa opc he did in CT beat 230kw ST's...murder she wrote all the way.
I know this corsaM3s also got drilled by this corsa
TMN wrote:A corsa OPC driver that I referred this tuner to got 160kw peak power but it holds really well from 4000 to 6500rpm torque is flatter.
